Author Topic: Need pics of firm feel sway bar installed  (Read 907 times)
« on: August 02, 2009 - 12:37:36 PM »
I would like to see pics of over size dia. front sway bar installed like Firm Feel sells. Above and below shots.
Were you able to keep any of the OEM brackets to be re used? Or does it require after market parts only.
Re: Need pics of firm feel sway bar installed
« Reply #1 on: August 02, 2009 - 03:04:05 PM »
my call is no , the brackets will be the wrong shape for the larger bushings , the original straps that attach to the K frame will work just the U shaped brakets for the bar will be wrong
« Reply #2 on: August 02, 2009 - 04:13:58 PM »
I just returned from the car show in Fremont Auto West Dodge and I saw that the brackets that clamp the bar onto the K frame bolted on brackets are much more narrow.
Offline autoxcuda
    • Spring Fling
« Reply #3 on: August 03, 2009 - 03:15:32 AM »
Just browsing through my stash of junk.... I have a 7/8" poly sway bar bushings part number 5.5113G . Those fit in the factory narrow U straps I have. That's a factory sway bar diameter.
Now question is, do that make a 1 1/4" diameter narrow bushing version that fits the narrow U straps? I can't find them, maybe call energy to see if they make such a thing.
Spring Fling XXX
April 22 & 23 2016
at Woodley Park Van Nuys, CA.
Fri: Caravan & Cruise
Sat: Mopar Cruise-In
« Reply #4 on: August 03, 2009 - 07:50:17 AM »
I own a set  of the 1 1/4" bushings that I was going to return , I need the 7/8" ones
