Author Topic: How do I remove this U joint?  (Read 2153 times)
Offline tactransman
Re: How do I remove this U joint?
« Reply #15 on: August 03, 2009 - 11:09:52 AM »
Also,make sure you put clips on the u joint caps that go into the rearend since they center it. I don't know how many times I have seen them left off because people think since they are not in the driveshaft,they are not needed.
Terry-tactransman
Union, Mo.
Offline DMZ73
    • http://www.pbase.com/dmz73/
« Reply #16 on: August 03, 2009 - 11:22:21 AM »
Locally it is around $100 , it shopuld be cheaper where you are unless labor rates are $!20 / hr there
check the slip yolk first , the 904 is different from the 727/833
 :clueless: I would not know what to look for, to tell you the truth..
the slip yolk would be where the driveshaft starts..correct? it looks like this ---(
I am sure the spline count is correct, because it slips over the tailshaft without issue, and turns the tailshaft of the trans.
Are the splines  of the slip-yolk different lengths? How much overlap do the splines needfrom the tailshaft to the slip-yolk?
BTW:I still can't access Autohobbydigest.com - It keeps saying 403 forbidden.
can you help me with a Copy paste fromt he website?
Thanks again guys,
Dan
Offline tactransman
« Reply #17 on: August 03, 2009 - 01:56:31 PM »
If it slips on the output shaft,the yoke is a 727.
Terry-tactransman
Union, Mo.
Offline DMZ73
« Reply #18 on: August 03, 2009 - 03:49:08 PM »
 :bananasmi :bananasmi :bananasmi
YEAH!!!! At least that is something that is right!
If all goes well, I should get the tailshaft today/tomorrow. I have no idea on what is involved with that, but there's a first time for everything....
I will take the driveshaft in to get it shortened Wednesday- 80$ est. 1day turn around :bigsmile:
Dan
Offline Aracer
« Reply #19 on: August 13, 2009 - 11:09:14 PM »
any chance you have one of these?........ or a good bench vice?
That tool in the big vice is great for saving the u-joint if you see that it's new and worth saving or if you upgrade the spline yoke. They will loan you a larger ball joint C press at AutoZone too.
