SO sitting at a car show today I noticed that my right rear was lower than the left.....well the car was on a slight grade, and that end was lower so I figured that was the deal.
Well, in my garage I am noticing it too...though my garage floor isnt perfect, its not a grade either....
The space in my wheel well on the right side is lower than the left ...by about an inch.
So, do you think I just have one rear spring that is saggier than the other?
My car sits at about 25 7/8" on the left and 24 7/8" on the right, measuring to the lip of the wheel wheel, on the centerline of the wheel.
Would installing helper springs as I saw in another thread help here or are new springs my only cure? Nothing else under there looks bent or anything.
Someone suggested that the front torsion bar settings could actually cause this......
But the front seems pretty level to me.....although the right side front measures about 1/4" low if I use the same measuring method.....assuming thats accurate.
Will tweeking up the right side front raise the rear somehow?
