Author Topic: 360 Block, where to get one?  (Read 1089 times)
Offline Glennster
« on: August 02, 2009 - 10:40:47 PM »
I need a 1970 360 block. I'm in northern Indiana, where can I find one cheap?
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
Re: 360 Block, where to get one?
« Reply #1 on: August 02, 2009 - 11:33:42 PM »
Try craigslist or local junkyards.    :2cents:
Don
Member Since January 14, 2002
« Reply #2 on: August 03, 2009 - 12:14:12 AM »
Why a 70? , 360s are everywhere
Offline Ck[FIN]
  • Get real - Get Mopar
    • Small car club from Finland
« Reply #3 on: August 03, 2009 - 05:17:51 AM »
71-74 could be a little stiffer than later blocks but later blocks are also pretty rigid stuff. I have 0.06" overbore in my 80`s block and it`s holding up very well.
Offline the_engineers
« Reply #4 on: August 03, 2009 - 09:59:37 AM »
You will not find a 1970 360...they didn't come out until 1971.  That said, here's one in Muncie.
http://muncie.craigslist.org/pts/1282258568.html
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline Glennster
« Reply #5 on: August 03, 2009 - 04:47:10 PM »
I screwed this question up pretty good. What I'd like to find is a 360 motor that would drop in without special brackets. I've got a 70 Challenger with a 318.
 I would like to stoke the 360 to 408..........
That one in Muncie may not be a bad deal.
« Reply #6 on: August 03, 2009 - 04:53:30 PM »
No problem...good luck  :thumbsup:
Brooks
1971 'Cuda 360
Offline 422STROKER
  • Member Since 6/3/06
« Reply #7 on: August 03, 2009 - 05:40:45 PM »
You can use any 360, no special brackets needed, and if you internally balance the new stroker then use regular Tq converters and balancer too.
Well, all 340-360's use a different bracket but I used a spacer with the 318 mount and it worked perfect on my 340.
Tom :2thumbs:
Tom
