Author Topic: Platinum or Copper  (Read 581 times)
Offline basement
Platinum or Copper
« on: August 03, 2009 - 06:08:41 PM »
So, went to my favorite discount store to pickup a set of Autolite 65's and after getting home noticed I picked up platinum plugs. Went ahead and installed them anyways. I've done a search on this forum for opinions but came up 50/50 for and against. My engine runs very rich and tends to load up, normal plugs last about 6mths of strett driving. I will run the plats and let you guys know the results.
Re: Platinum or Copper
« Reply #1 on: August 03, 2009 - 06:42:50 PM »
why not adjust ther carb to run leaner ?
Offline e-tek
  • My website: http://edanneberg.googlepages.com/home
    • E-Tek Resto's
« Reply #2 on: August 03, 2009 - 09:16:26 PM »
You guys are always looking for the easy way out!! ;)
Offline 72cudamaan
« Reply #3 on: August 03, 2009 - 09:49:41 PM »
Or at least the common sense way out :roflsmiley:
If I cant fix it, it's broke
Andy  (phukker whither)
Offline basement
« Reply #4 on: August 04, 2009 - 08:29:38 AM »
Ya think.
Actually I've leaned out this Edelbrock with the smallest jets available in my jet kit and still have a rich situation. If anyone has some other ideas please let me know.
« Reply #5 on: August 04, 2009 - 10:14:59 AM »
lower the float level , lean the idle mixture , make sure the choke is coming off completely , advance the timing for starters
Offline basement
« Reply #6 on: August 04, 2009 - 12:27:57 PM »
thank Chryco, good suggestions.
