Author Topic: Run on  (Read 1503 times)
Offline pink panther
Re: Run on
« Reply #15 on: August 05, 2009 - 01:43:17 PM »
my built 340 tends to diesel unless I add octane booster to it,
Offline shadango
Re: Run on
« Reply #16 on: August 06, 2009 - 08:30:16 AM »
On the topic of additives, should I be running a lead additive in my 76 318 with J heads?  I am not sure what year the heads are....
Offline Changin Gears
Re: Run on
« Reply #17 on: August 06, 2009 - 08:45:50 AM »
You could add an idle solenoid like the 6-paks had.
Offline 72cudamaan
Re: Run on
« Reply #18 on: August 06, 2009 - 09:28:14 PM »
Well it sounds like you have a problem in your idle circuit as well. You shouldn't have that big of an rpm drop going into drive!
If I cant fix it, it's broke
Andy  (phukker whither)
