Author Topic: Fluids- A833 and Dana 60 recommendations  (Read 3682 times)
Offline tommyg29
« on: August 04, 2009 - 11:08:55 PM »
I have an 833 4 speed, and a 3.54 powr-lok. The rear has amsoil severe gear 75-90 in it now, and it has been dripping, but very slowly, so I want to check that and top it off. Only has 1000 miles in 3 years on it. Should it be replaced because of age? I hear this oil has the modifiers needed for the clutch, and is rated best by everyone I've talked to.
Also, What fluid for the tranny, which also has dripped a little.
Thanks for any advice.
Re: Fluids- A833 and Dana 60 recommendations
« Reply #1 on: August 05, 2009 - 03:12:29 AM »
I wish i was a chemical engineer , the arguement will start again soem say 80-90 is best others use 75-90 synthetic , I can tell you GL4 os good for manual trannys while GL5 is too slippery for the syncros to work correctly , I have used Redline Manual trans oil & it will shift properly as for the diff synthetic could cause brg & gear problems
Offline tommyg29
« Reply #2 on: August 13, 2009 - 04:44:55 PM »
Thanks Chryco.
Not looking to start up any old arguments.
Since amzoil is in my tranny now, I just want to top it off. Just bought it a month ago, and I want to make sure it has enough fluid in it. I see the drain plug on the left side. Where is the fill hole?
Thanks.
« Last Edit: August 13, 2009 - 04:48:34 PM by tommyg29 »
Offline tommyg29
« Reply #3 on: August 13, 2009 - 04:47:35 PM »
ooops, I see it, higher on the right side. Just fill it till it comes out then?
« Reply #4 on: August 13, 2009 - 10:25:08 PM »
I just fill it till it leaks out, but I use Mopar ATF-3.
Offline tommyg29
« Reply #5 on: August 14, 2009 - 08:17:47 AM »
Ok. Maybe I should drain the amzoil and refill it anyway. Dont imagine another type oil should be mixed.
Thanks.
Offline tommyg29
« Reply #6 on: August 14, 2009 - 06:17:41 PM »
I quit. Checked 4 stores, and No one around here sells anything rated gl4. Guess I'll have to order online. I'll try the amsoil site.
Thanks
« Reply #7 on: August 16, 2009 - 09:02:13 PM »
The service manual recommends Dexron ATF fluid for the A833. I tried 75/90 in it once just for an experiment and the syncro's didn't work well with the thicker fluid. For the rear end - You can't go wrong with AMZOIL. :2thumbs:
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #8 on: August 18, 2009 - 06:55:38 AM »
:iagree: i like the redline manual trans oil,,it seems to work great
72rtchallenger
what happens in the garage
stays in the garage
Offline tommyg29
« Reply #9 on: August 18, 2009 - 08:45:50 AM »
I ordered a qt of redline 90 mt from Summit since it was convenient to add it to an order.
Any problems using it to top off the existing amsoil in the unit.
No problems mixing the two, theyre both synthetic.
  • 72 to 70 clone
    • cardomain
« Reply #10 on: August 18, 2009 - 06:23:59 PM »
 :dunno: unsure but i used it  with gl4 ,,with the amsoil it maybe over kill and to thin,but i am  :dunno:
72rtchallenger
stays in the garage
