Author Topic: 318 Two to four barrell advice  (Read 9455 times)
Offline 71chally416
    • The Streetwalker
Re: 318 Two to four barrell advice
« Reply #15 on: September 02, 2009 - 06:07:09 AM »
I had both a 1850 600 Holley and a 800 Thermoquad on my old 318 and it definately liked the TQ better, but I had to modify the LD340 Intake to use it because of the spread bore. The small Thunder AVS would also be a good choice for a LD4B Intake on a 318.
Offline thesado
  • 1972 Barracuda 318 GY4
« Reply #16 on: September 02, 2009 - 03:00:32 PM »
So does it matter what specific carb I buy?  I'm finding a lot of Holley's available on ebay.  Hypothetically if I look for a 570 or 600 and find one off of a 92 chevy truck, is that still going to work for me?  Are they similar, or engine specific? And what are the differences between the Avenger and Traditional?
« Last Edit: September 02, 2009 - 03:24:12 PM by thesado »
« Reply #17 on: September 02, 2009 - 06:18:04 PM »
the newer Holleys are better calibrated & have better adjustment features on some , if it is a spread bore style it probably will not fit well depending exactly waht intake you use
Offline UKcuda
  • Tell them I'm on my way
« Reply #18 on: September 03, 2009 - 05:13:27 AM »
A few years ago I "matched" a stock 340 4bbl inlet onto a 318 by blending out the first inch of the ports on the heads using little grinding wheels on my drill.  It went like hell.  Not so easy without taking the heads off the motor though !
Ironically, I have a 360 here that someone has put a LD4B on !
'72 'cuda
Offline thesado
« Reply #19 on: September 03, 2009 - 09:02:30 AM »
I've decided on the LD4B since I've read so many good reviews.  The carb is what I'm not sure about.  I'm thinking about a Holley 600, but I'm interested more in daily driving performance (torque?) than peak rev power, so maybe the 570 would be better.  I've got a lead on an LD4B + Holley 670 (which I think is too big and I'll have to swap for smaller) but I don't know what would be a fair price for it.  And how much is an LD4B worth by itself?
« Reply #20 on: September 03, 2009 - 12:52:56 PM »
Get the LD4B where youy can , they are disconintued
 if the 670 come with try it for a while
Offline 318Sebring
« Reply #21 on: September 03, 2009 - 09:19:40 PM »
I have an LD4B Intake with an old Carter 625 on my mild 318 .
Good all around set up Works very nice
thesado " And how much is an LD4B worth by itself?" Last year I paid $ 125.00. It looked almost new.
« Last Edit: September 03, 2009 - 09:27:22 PM by 318Sebring »
Offline 71chally416
    • The Streetwalker
« Reply #22 on: September 03, 2009 - 09:58:49 PM »
If you're looking for TQ from a 318 you're probably gonna be dissappointed. That's like looking for gas mileage with a 500 cube stroker motor.  :lol:
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #23 on: September 04, 2009 - 10:35:28 AM »
A long time ago I had a 318 in an '82 5th Ave.  The 2 barrel setup not only didn't offer any low end power, but also had horrible top end.  I switched over to a Weind DP intake and a Holley 600cfm carb and the difference was great.  The top end was really good too.  With the 2 barrel, I literally had the gas pedal on the ground driving through Vermont and a VW Rabbit buzzed by me.  I'm guessing I was only doing about 90+mph.  With the 4 barrel, I got it to about 105mph with about 1-2" more pedal travel. (My speedo only went to 85mph, the Trans Am I was tailing told me how fast we were going.  ;D )
I later switched to a Rochester Quadrajet (Sorry, I know GM and Mopar parts aren't supposed to mix but that's what I had lying around.  :dunno: )  The Q-jet is a spreadbore like a Thermoquad.  I found the the low end pick up was actually better with the QJ vs the Holley due to the smaller primaries since I had not done a cam change.  :2cents:  Soooo...if you have a QJ lying around....  :poopoke:  :stirpot:
Offline Glennster
« Reply #24 on: September 04, 2009 - 09:29:11 PM »
 I went with the Edelbrock 2176 Intake and a 570 Avenger, it made a huge difference!
They're both going up for sale in about 2 weeks since I'm about to install a stroked 340.
If I had it to do over, I'd run with the same set up..................................
Offline thesado
« Reply #25 on: September 09, 2009 - 02:36:46 PM »
Update: Found an LD4B, its on its way (thanks Mike!).  After a lot of consideration I think a traditional Holley 80457 600cfm should work well for me. The avenger looks awesome, but I cant justify the cost for the difference.  Looks like all I'll need then is a breather.  Will any breather fit?  or are they carb specific?
« Reply #26 on: September 09, 2009 - 05:09:14 PM »
all carbs use the same diameter base for the Air cleaner except the huge dominator series carbs , you can use a generic 14" drop base ac with a 3 " element like a K&N
Offline Glennster
« Reply #27 on: September 10, 2009 - 06:26:15 AM »
thesado,
 Did you get my PM concerning the 570 Avenger I've got for sale? THAT should be affordable......................6 months old, about 1,000 miles on it, with the original box..............
 The reason I'm selling it is that I'm buying a bigger motor.
Offline thesado
« Reply #28 on: March 08, 2010 - 10:22:12 AM »
Looked into starting the conversion process over the weekend.   :working:  I'm trying to make sure I have EVERYTHING I need before I tear into the engine.  I don't want any surprises.  So I'm wondering if I can use my stock throttle linkages, etc, or if I need to modify.  And what is a throttle extension? Do I need one?
My car has AC (broken system), so I'm wondering if I should just remove the compressor altogether to avoid hassling with the mounts.  Thoughts?
So far I have only the LD4B (needs painted) and a Holley 650 dbl pumper (would have preferred lower cfm, but this deal was too good to pass up).
The list of things I still need to get:
air cleaner
carb gasket
port gaskets
carb mount studs
fuel line
am I missing anything?
Thanks!
From
To this
« Last Edit: March 08, 2010 - 11:50:05 AM by thesado »
« Reply #29 on: March 08, 2010 - 12:05:04 PM »
you will need a 20-7 linkage adapter for the carb
