Author Topic: 318 Two to four barrell advice  (Read 9454 times)
Offline thesado
  • 1972 Barracuda 318 GY4
Re: 318 Two to four barrell advice
« Reply #45 on: April 09, 2010 - 09:03:15 AM »
1.5 turns is a good starting point for the idle but you need to fine tune the idle screws once the motor is running.
I'm not sure how to do that.
Quote from: Chryco Psycho
installl a powervalve with at least a 2" lower rating
In the pri or sec? The pri already has one, but I didn't look which.
« Reply #46 on: April 09, 2010 - 10:50:08 AM »
primary only , I thought it had had a plug installed the way you described it .
basically turn in the screws until the rpm drops then turn them out until the rpm levels off & go maybe 1/4 turn out more
