Last time I was at your place with my Chally, first time with the Alterktion and it's Unisteer R&P, I parked as usual next to your work van, on the lawn.
Before when I parked there, it was easy to just turn right and drive away.
But this last time, with the new K-frame and Unisteer R&P, my front ended up at your neighbours fence when I turned right, and I had to back up a little before I was clear.
Too bad Frank was in a hurry then, so there was no time for you to test it there and then. And the day after, the freaking converter/tranny went south...
If Cato and the good people at Frame-Works have the Chally in working order before fall, maybe it's possible to arrange a test drive for you, so you can find out for yourself?
(A little off topic: RMS does tell in advance that the turn radius will increase, and it does. But the cornering abillities really makes up for it, and that's my opinion already before the suspension is dialed in!)
