Everything came together last night with not too many extra parts left over
.... The most difficult single aspect was removing & reinstalling the dip stick tube, that's to say low difficulty level. I did have to get a little creative installing the shift seal, I was under the impression that it could be driven in but there was no room. Instead I used a large bolt & nut with washers to pull the seal down into it's recess.
An interesting detail, one of the modifications Terry/tactransman illustrates in his phase-2 post has been done & that had to be prior t0 '79. The wall beside one of the check balls had been removed.
I was surprised to find so much brown sludge still in the valve body...Background, 3-years ago when I started working on the car after it had sat for 17+ years I changed the fluid & what was in the pan was a brown sludge. I ran an extra gallon of fluid through it at that time letting it out the cooler line while adding through the filler tube until it ran clean. Since then the only use the car has seen is to be moved to the driveway & back or put on jacks stands & run. The fluid in the pan looked OK & there was just a smidgen of metallic shavings collected at the filter. Does this sound reasonable?
Again, Thanks Terry & Rob for your Support.
