Author Topic: Question for BruteForce  (Read 1207 times)
« on: August 10, 2009 - 09:56:17 PM »
I see from a picture you posted of your engine compartment, you have an MSD 6al box. Does your stock tach work? Did you have to use any adapters to make it work?
Offline BruteForce
  • '72 Dodge Challenger 340 5spd
Re: Question for BruteForce
« Reply #1 on: August 10, 2009 - 10:59:26 PM »
I have not attempted to hook up the stock tach to the MSD box. I read that it will not work. My evil plan is, once the engine is running, invest in replacing the guts of the tach with an electronic one from rt-eng that will work with the MSD box.
The other option is using an adapter, but I think replacing the tach guts is only slightly more expensive, and is a much better solution.
http://rt-eng.com/mediawiki/index.php/RTE_67-74_Tach_kit
The FAQ link on that page has a lot of intesting information.
Offline 6packCuda
« Reply #2 on: August 11, 2009 - 06:56:33 AM »
To get your factory tach. to work with the MSD ignition you need one of these...http://www.summitracing.com/parts/MSD-8920/
Offline BruteForce
« Reply #3 on: August 11, 2009 - 04:42:43 PM »
It's $59 for the tach adapter, and $75 to fix the tach itself. That's why I chose to go with the latter, as the result is the factory look but with modern performance.
« Reply #4 on: August 11, 2009 - 09:45:45 PM »
Thanks for the info guys. I was wondering if I needed an adapter or not, but I really like the idea of replacing the tach's guts. I'll order up the kit in a day or two. I hope it's as easy to swap out as they say. Once I get it working, I'll get the msd box.
Offline BruteForce
« Reply #5 on: August 12, 2009 - 03:08:25 AM »
I also plan to keep the old tach guts, in case when I sell the car (or my relatives after I'm gone!) someone can do a resto if they wish. I've got a number of boxes of old junk like that I've replaced.
« Reply #6 on: August 12, 2009 - 12:51:09 PM »
"I've got a number of boxes of old junk like that I've replaced."
Would that mean you tried the clock conversion from RTE?
Offline BruteForce
« Reply #7 on: August 13, 2009 - 01:19:05 AM »
Quote
Not yet. I promised myself I'd get the car running before revamping the dash & instruments.
« Reply #8 on: August 13, 2009 - 10:05:07 PM »
Makes sense to me :thumbsup:
