Author Topic: Is this steering column correct for a 1970 cuda?  (Read 818 times)
Offline svenjorgensen
« on: August 11, 2009 - 04:04:08 PM »
I like to know if this steering column, that came out from 1971 Challenger is correct for a 1970 Cuda? :clueless: :1zhelp:
Is it for a power steering? or manual?
Thanks for the help it is appreciated :-)  :drunk:
Re: Is this steering column correct for a 1970 cuda?
« Reply #1 on: August 11, 2009 - 04:09:54 PM »
no it is not correct for a 70 only steering column, but will work.  Looks to be a power steering assembly since the shaft is short
« Reply #2 on: August 11, 2009 - 05:45:19 PM »
It looks like a power steering shaft to me. The only thing that scares me is the turn signal switch for 70's was a one year only thing. I don't know if there would be a compatibility issue with plugging this switch into your existing wiring.    :dunno:
« Reply #3 on: August 12, 2009 - 02:44:06 AM »
yes it will work OK  & no it is not correct the 70 column had a interlock to the tranny to rotate the column to get the key out
 the TS switch plugs in just fine
« Reply #4 on: August 12, 2009 - 09:16:35 AM »
Thanks  :cheers:
