Author Topic: Troubleshooting oil pressure gauge  (Read 4901 times)
Offline BruteForce
  • '72 Dodge Challenger 340 5spd
« on: August 13, 2009 - 05:04:31 AM »
When I fired up my engine, the oil pressure idiot light went out, indicating pressure. But the (stock) oil pressure gauge didn't budge. With the power off, I measured the resistance of the water temp sender as a few ohms, but the oil pressure sender measured as infinite resistance (open circuit).
What should be the resistance of the sender when the engine is off? (It's a new one I got from Rockauto, as my old one disappeared.) Anyone know what the resistance of the sender should be at, say, 50 psi?
I've looked at a lot of ads for senders, and not one of them mention any of their electrical characteristics.
Offline BruteForce
Re: Troubleshooting oil pressure gauge
« Reply #1 on: August 13, 2009 - 05:21:32 AM »
I should add that yes, I'm getting a pulsing 5V signal on the sender connector, and the gauge pegs when the sender wire is grounded.
Offline BruteForce
« Reply #2 on: August 13, 2009 - 05:29:32 AM »
I did some more googling, and suspect that 0 PSI should be 240 ohms, and max pressure (whatever that is) should be 33 ohms. As my sender measures an open circuit, it's probably bad.
« Reply #3 on: August 13, 2009 - 11:46:31 PM »
I agree , if you have 5 v at the sender & the gauge moves when the wire is grounded the sender is the problem , do not tighten with the body either , there is a nut under the body for tightening it in ,use it
Offline BruteForce
« Reply #4 on: August 14, 2009 - 04:15:42 AM »
Hmm, I did hand tighten it using the bell, not the nut. Could that have busted it? I didn't apply much force. Anyhow, I ordered a cheapo mechanical gauge I intend to screw in to test to see that I really do have oil pressure and it's the sender.
« Reply #5 on: August 14, 2009 - 01:25:40 PM »
Yes it can damage it threading it in by hand , I bet you have oil pressure , the lifters would be talking to you if you didn`t have pressure
Offline BruteForce
« Reply #6 on: August 14, 2009 - 03:14:53 PM »
Well, with just headers and no exhaust, there wasn't much hearing of other things going on! I expect to get the new mufflers delivered today (the ones TTI originally shipped to me didn't fit, they are sending replacements at no charge. Their customer service is very good.  :thumbsup:).
I'm also pretty sure there is oil pressure because the engine was run in on a dyno before sticking it in the car. I figured it would be a lot easier to correct any deficiencies that way rather than having the aggravation of having to pull it out again.
While I wait for the mufflers and a few other parts needed to get the car rolling, I worked on cleaning the mags. It has old school mags which I really like. The modern Foos style spoked ones don't work for me.
« Reply #7 on: August 14, 2009 - 06:33:09 PM »
 :2thumbs:
Offline BruteForce
« Reply #8 on: August 15, 2009 - 11:31:12 PM »
A standalone mechanical oil gauge arrived in the mail today. I screwed it in and fired up the engine. Got lots of pressure, so it clearly is a bad sender. That's a relief! :jumping:
« Reply #9 on: August 16, 2009 - 08:44:40 PM »
Good to hear it's all sorted out. Just out of curiosity I checked the resistance of my stock sending unit with the engine off. 83.5 ohms.
« Reply #10 on: August 16, 2009 - 08:48:02 PM »
I like your taste in rims. Let me know what you think of the TTI's. I'm looking around for an exhaust system to install this winter.
Offline BruteForce
« Reply #11 on: August 17, 2009 - 05:14:15 AM »
So far, the TTIs have been a struggle. I haven't figured out yet if I'm doing something wrong or not. I'll try again tomorrow. Part of the problem is the 3" exhaust X pipe is big and heavy, and I'm working on my back under the car with very little room to maneuver. A bit of graphite paste helps with the slip fits.
I may wind up having to take it to a muffler shop.
The TTI headers are nice, though you'll need a 90 degree oil filter adapter and a mini starter. On the passenger side, I had to grind a half moon out of the Lakewood bellhousing to clear the headers. On the driver side, it interfered with the torsion bar and I had to put in some Schumacher spacers to move the engine to the right.
Quote
That's great information, thanks! I suppose what I can do is hook up a potentiometer and measure the ohms that correspond with various gauge positions, then I can match it to a sender. I don't like the stock sender, it's too large.
Offline BruteForce
« Reply #12 on: August 17, 2009 - 05:20:50 AM »
Quote
Me too  :) I got lucky in that these came with the car. I don't know what brand they are, and have never seen them elsewhere. I also like the satin finish, rather than chrome. My bumpers need rechroming, and I've been toying with the idea of doing a nickel plate rather than chrome. Nickel has a more understated, elegant look than chrome.
Offline BruteForce
« Reply #13 on: September 07, 2009 - 03:03:08 AM »
Update: Schuck's had senders in stock, so I bought a new one, installed it, and it appears to work fine.
« Reply #14 on: September 07, 2009 - 12:15:11 PM »
when installing the TTi exhaust start at the rear , hang the tail pipes first then slide the mufflers in ,, use the rear hangers & the large hangers to support the system then slide in the X pipe & the front adapters to the headers , line up the system so it sits straight & start tightening everything up
