Author Topic: Tire dia affect on gear ratio  (Read 2008 times)
Offline Purple73Cuda
« on: August 13, 2009 - 12:29:59 PM »
I am planning on changing my F70x14 tires to 15" radial tires. Is there a formula to figure out how the gear ratio would change by installing a taller ( or shorter ) tire?
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
Offline Oldschool
  • Member Since 9-05-06
Re: Tire dia affect on gear ratio
« Reply #1 on: August 13, 2009 - 01:03:35 PM »
Here ya go Purple73,
This little calculator uses a familiar dash layout for you to work your calculations with.  Just enter the information and it does all the work.  Just change any of the variables to get a new answer....     :2thumbs:
http://vexer.com/68rt/speed.html
Ken  --  In Georgia
Offline CUDA JAS
  • vroooooom!
« Reply #2 on: August 13, 2009 - 01:12:23 PM »
you can alos try one of the spreadsheets at this link.
http://www.moparts.org/Tech/tech/pages/speedo.html
Jas
74 'cuda 360/727
Just call me a gearhead!
« Reply #3 on: August 13, 2009 - 03:45:47 PM »
Very good info guys.
I guess what I am asking is, in your experience if I go from a F70x14 to a 275/60x15, do I need to change the 3.23s to 3.55s to have the same acceleration with the taller tires?
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
« Reply #4 on: August 13, 2009 - 07:01:03 PM »
An F70X14 is how tall?  Even if it's 225's, the 275/60X15 will be taller.
« Reply #5 on: August 13, 2009 - 07:44:19 PM »
I would think the extra traction would be more than make up for any possible loss of quickness by the larger diameter.
« Reply #6 on: August 14, 2009 - 07:39:32 AM »
The F70x14 is 25.85" tall and the 275/60x15 is 28". I am wondering if the 2"difference is going to make the car act like it has 2.76s or a gear less than 3.23s.
Yes the traction and the look is going to make a big difference in the car. I just don't want to lose too much quickness.
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
« Reply #7 on: August 14, 2009 - 09:12:20 AM »
I put your #s in this chart using 215-70-14 for tire size & the difference is not that much IMO in 1st gear about 2-mph change at any RPM
http://www.moparts.org/Tech/tech/img/AUTOMATICchart.xls
215-70-14
GEAR   GEAR RATIO   MPH/1000RPM   MPH AT RPM
         1500   2000   2500   3000   3500   4000   4500   5000   5500   6000   6500   7000   7500
1st   2.65   9.00   13   18   22   27   31   36   40   45   49   54   58   63   67
2nd   1.57   15.20   23   30   38   46   53   61   68   76   84   91   99   106   114
DRIVE   1.08   22.05   33   44   55   66   77   88   99   110   121   132   143   154
275-60-15
1st   2.65   9.74   15   19   24   29   34   39   44   49   54   58   63   68   73
2nd   1.57   16.46   25   33   41   49   58   66   74   82   91   99   107   115   123   132   140
DRIVE   1.08   23.87   36   48   60   72   84   95   107   119   131   143   155   167
Offline shadango
« Reply #8 on: August 17, 2009 - 10:19:04 AM »
Hey, this link is COOOOL!  :2thumbs:
I could play with this all day!  Just the tool I was looking for!  Easy enough for an idiot like me to use!
And it seems accurate, using my current gear ratio, tire size etc.....seems to match up with the tach I get now, etc.   AWESOME!  :bigsmile:
