Author Topic: What's the proper way to do this?  (Read 726 times)
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« on: August 14, 2009 - 02:08:18 AM »
With an aftermarket air cleaner, what do you do with the vent hose in the valve cover?  I figured it was a dirt magnet if not filtered somehow.  How else can I do this without it looking ghetto?
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Re: What's the proper way to do this?
« Reply #1 on: August 14, 2009 - 01:14:51 PM »
there is a filter mesh inside the breather that cna be cleaned with varsol or similar , or you can run a K&N breather in place of the factory breather
Offline ntstlgl1970
  • T a c o c a t
« Reply #2 on: August 14, 2009 - 01:31:52 PM »
alternately, you could buy an elbow fitting that bolts to the inside of the filter base (you would have to punch or drill the holes). Some aftermarket bases already have a knockout plug to facilitate the fitting. Then attach the breather hose to the fitting.
Offline Aussie Challenger
« Reply #3 on: August 17, 2009 - 07:18:44 AM »
  At low engine speed air is drawn in through the breather because the PVC is drawing the fumes from inside the motor into the inlet manifold to be burnt. However under hard driving there is blowby past the rings and the PVC pipe cannot handle all the excess pressure build up so the extra goes out the breather and that is why it should be connected to the air cleaner inside so it can be burnt as well without making an oily mess over the rocker cover.   :2thumbs:
