Author Topic: Dutch Brothers Fabrication - Crazy Eight Lift And K Member Remover  (Read 5332 times)
Offline daveh
Hi Guys,
I'm going to be pulling the engine and trans from my 71 Challenger for the new 5 speed and refresh the engine and I saw that Dutch Brothers has what they call a Crazy Eight Lift And K Member Remover.  It looks like an easy way to do the job from the bottom.  However I can't justify spending the $350.00 for using it once or twice.
Here is the link to it:
http://www.crazyeightlift.com/index_files/Page532.htm
I was just wondering if anyone had one out there that I could borrow for a while?  Obvously I would pay for the freight to and from I just can't justify spending that money for a one time use. Thanks
Offline Mike70
  • Future Challenger Pilot
Re: Dutch Brothers Fabrication - Crazy Eight Lift And K Member Remover
« Reply #1 on: August 14, 2009 - 10:27:31 AM »
Looks good, but you could make your own with some square tubing and a few wheels. I'll bet someone on here has already done it! :2thumbs:
70 Challenger RT/SE
(If I ever get it done - wait, I guess I have to start first).
Offline 67vertman
  • Member since 9-23-2005
« Reply #2 on: August 14, 2009 - 08:21:41 PM »
Looks like it would be easy to fabricate.  Four castors and some square tubing, probably cost you less than $100 in parts.
« Reply #3 on: August 14, 2009 - 11:21:54 PM »
I made this (pictured) then attached it to a 1000 lb capacity mover dolly I bought at Harbor Freight.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93614
Then I bought the smaller one and X crossed connecting the two together using bolts mounting the angle iron thru the wood frame for support for the 2 dollies.
This rear dolly will be for the tranny weight to be supported.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93888
« Reply #5 on: August 15, 2009 - 03:34:58 AM »
I just use pads to go under a snowmobile , 3 pads for $50 with the castors & hold 1000 lbs
