Author Topic: 383- 727 trans problem  (Read 962 times)
Offline 70 R/T
« on: August 16, 2009 - 02:57:11 AM »
Hi,took my challenger out recently,been in garage as winter here,running good ,upshifting good and will downshift with good kick on gas pedal,my issue is it doesnt want to change down when coming to stop,tries to take off in high gear,also when manual shift from standstill from 1st to 2nd feels like braking ,only does this with manual shifting ,ok when in drive,trans fluid clean and correct level,any ideas whats wrong,have checked kickdown linkage and seems fine.cheers :nzflag:
Paul
1970 Challenger R/T
1970 Challenger W.S.S
1965 Chev Impala SS
1969 Chev Camaro RS/SS
1972 Chev Corvette Roadster
1975 Pontiac Trans Am
1985 Chev Corvette
Re: 383- 727 trans problem
« Reply #1 on: August 16, 2009 - 10:20:22 AM »
 :popcorn:
Offline oldkimmer
« Reply #2 on: August 16, 2009 - 02:29:20 PM »
 :canada:...........the govenor is sticking, thats y it takes off in a higher gear after a stop...........tail housing needs 2 come off 2 clean it...........kim.......
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
Offline Ck[FIN]
  • Get real - Get Mopar
    • Small car club from Finland
« Reply #3 on: August 16, 2009 - 02:53:30 PM »
Offline 70 R/T
« Reply #4 on: August 16, 2009 - 08:23:26 PM »
Ok, thanks guys,will take apart and clean,would this also be part of my manual shift problem i mentioned. cheers
Paul
1970 Challenger R/T
1965 Chev Impala SS
1985 Chev Corvette
Offline tactransman
« Reply #5 on: August 16, 2009 - 09:54:03 PM »
If you want try a little trick? take it to a spot with some pea gravel and spin the tires in it. Works sometimes. :cheers:
Terry-tactransman
Union, Mo.
« Reply #6 on: August 16, 2009 - 09:55:30 PM »
What is Pea gravel?  Small rocks?
Offline 70 R/T
« Reply #7 on: August 16, 2009 - 11:21:56 PM »
ok,will give the gravel spinning a try,hope it works to free up govener. :cheers:
Paul
1970 Challenger R/T
1965 Chev Impala SS
1985 Chev Corvette
Offline tactransman
« Reply #8 on: August 17, 2009 - 07:03:13 AM »
Yup.  :grinyes:
Terry-tactransman
Union, Mo.
