Author Topic: Powder coat and wheel bearing seal  (Read 649 times)
Offline Gmoff22
« on: August 17, 2009 - 02:20:45 PM »
Wondering if anyone out there has any experiecnce with putting a wheel bearing seal over powder coat?  I had my steering knuckle powder coated and they coated right up to the spindle (the spindle is not coated).  So where the bearing seal will sit is coated.  My question is where the seal meets the powder coat will it make a good seal or will it cause problems?
Thanks,
G-
G-
USAF Pilot
'72 Challenger Rallye - http://s595.photobucket.com/albums/tt36/gmoff22/Challenger/
'05 Ram SRT-10 Quad Cab - http://s595.photobucket.com/albums/tt36/gmoff22/SRT-10/
'05 Magnum R/T AWD
Offline cudazappa
Re: Powder coat and wheel bearing seal
« Reply #1 on: August 17, 2009 - 05:43:42 PM »
I had the same issue with my spindles on my 300... I used a dremel with a light abrasive and removed just the powder from the offending areas.  I didn't try running the spindles with the powder on them...
2015 Dart GT - Daily Driver
Offline dutch
« Reply #2 on: August 17, 2009 - 05:50:16 PM »
big chance you will get problems down the road.   the powder is adding pretty much to the diametre. I`d take it off.
*** Bart ***
Offline Gmoff22
« Reply #3 on: August 18, 2009 - 04:38:32 PM »
thanks for the info I'm going to take it off, to save the potential for heatache in the future.
Thanks again,
G-
G-
USAF Pilot
'05 Magnum R/T AWD
