Author Topic: brake booster problems?  (Read 706 times)
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« on: August 17, 2009 - 10:13:42 PM »
i replaced my front brake system to a 73 setup as it is better,and converted to a 4 spd so the pedal was a little different.,the problem i am haveing is that the brake pedal sticks alittle,,,just enough to cause the brake lights to be on ,,an barley engauge the front brakes which squeals,,i can pull the pedal up enough to make the lights go out and most of the squealing stop but not all noise,,all parts new except booster,,the pedal is alittle stiff but that doesnt bother me,but will the booster allow these problems if it needs rebuild or replaced  :clueless:
72rtchallenger
what happens in the garage
stays in the garage
Offline burdar
Re: brake booster problems?
« Reply #1 on: August 17, 2009 - 11:21:31 PM »
A bad booster can cause the pedal to partialy apply the brakes.  Did you have a problem before swapping the brakes or is the booster something you just added?
« Reply #2 on: August 18, 2009 - 01:36:37 AM »
didi you lube the linkage under the dash ??
  • 72 to 70 clone
    • cardomain
« Reply #3 on: August 18, 2009 - 04:26:25 AM »
new problem but its been a 5 yr restro and its the orignal 1972  booster
72rtchallenger
stays in the garage
  • 72 to 70 clone
    • cardomain
« Reply #4 on: August 18, 2009 - 04:27:29 AM »
no ,,havent checked it yet either
72rtchallenger
stays in the garage
