Pretty tight fit getting over the rotor. I even loosened the caliper mounting bracket bolts to work it on. There are some cooling webs all on the inside of the rotor where the large bearing is at. But it looks low enough not to interfere.
Here's my
. Please forgive me on the details as I have done brakes before but not on my Challenger. I don't think this is normal as you don't want to drive around with the pads dragging as this will glaze the pads. Same effect as riding on your brakes around town.
What year Cuda are we dealing with? I know there are slide/pin type calipers. Not sure what we are dealing with.
If the caliper with the pads loaded are tight to even go over the rotor, my guess is that the issue is that the issue is with the caliper/pads.
Without the caliper bolts in the caliper, does the rotor still seem to have the same amount of resistance to movement as when everything is bolted up?
If there is the same amount of resistance to movement, then the issue is with the caliper/pads. Make sure that the piston is 100% flush with the caliper and that the inner pad (the side with the caliper piston) is 100% flush to the caliper surface. Ditto as well for the outer pad, making sure it is 100% flush with the caliper surface. Make sure that none of the piston seal is getting caught between the pad and the caliper/piston.
If there is less resistance to movement with the caliper bolts
not installed (if this is correct for this particular set up.), then my guess is with the way the new calipers are setting on the old caliper brackets (I assume that you are reusing the old brackets as I did not see them on the list of new parts.)
Last but not least, contact the eller to see if there are known problems for this set up and make sure all the part numbers are correct.
Hope it gets all worked out!
