Author Topic: Trailer weights  (Read 952 times)
Offline Purple73Cuda
Trailer weights
« on: August 18, 2009 - 12:17:30 PM »
Approx. how much does an open trailer weigh? I was wondering if my 02 Dakota 2 wd 4.7 V8 5 speed would tow the 73 Cuda (340 4 spd.) on an open trailer. The truck has the towing pkg. and max. cooling pkg. The owners manual says I can tow 5450#.
Anyone tow with a similiar setup?
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
moparniac
Re: Trailer weights
« Reply #1 on: August 18, 2009 - 12:21:48 PM »
I think around 15-1600 range  :working:
Offline farmertan
Re: Trailer weights
« Reply #2 on: August 18, 2009 - 12:24:41 PM »
All depends on the material used to build the trailer, aluminum, steel. length, but on average I think you will be fine. I would guess anywhere from 800lbs to 1500lbs for most 14 to 20ft trailers.
73 340 4sp 2nd owner since 85    brett
Re: Trailer weights
« Reply #3 on: August 18, 2009 - 01:41:23 PM »
Your Dak could tow it but will be at the upper end of its limits. You could do it for a short trip across town, but it would be a risky proposition for any extended length or anything involving big changes in elevation. Lets say 3800# Cuda, 1500# trailer, your at 5300#. Possible, but not ideal. I don't know the torque range of the 4.7, but it probably isnt the greatest for towing big loads like that.
Offline pink panther
Re: Trailer weights
« Reply #4 on: August 18, 2009 - 02:26:28 PM »
make sure you set up for trailer brakes, I pull my 73 chally on a open trailer with my Ram 1500 4x4, squats the truck decent amount, so I would be concerned how much load the dakota can take
Offline vinb
Re: Trailer weights
« Reply #5 on: August 18, 2009 - 09:44:02 PM »
Average 21' open trailer is approx. 1,250 lbs. the Cuda with a small block is probably around 3,500 lbs.. plus extra stuff like tools/parts/etc. another 500lbs.
 Your pushing your luck with the Dakota, Back in the 70's I towed with a '75 Dodge 1/2 ton 2wd pick-up w/a small block auto and that was pretty much the bear mininum.
  If your staying local like 1 to 2 hr. trips it would not be too bad. If you have hills to deal with it could be a problem.
  Made sure your truck & trailer brakes are in excellent shape....
« Last Edit: August 18, 2009 - 09:48:12 PM by vinb »
Offline 69bronzeT5
  • SRT Guru
  • Mopar or No Car
    • Forgotten Mopars
Re: Trailer weights
« Reply #6 on: August 18, 2009 - 10:39:48 PM »
So basically, if I decided to tow my stripped '70 Coronet on a Uhaul trailer over numerous mountain passes (12hr trip approx.) with a '93 Cherokee Country 4X4 with a H.O 4L....bad idea? Not even considering snow ;D
Associate Editor for Mopar Connection Magazine
http://moparconnectionmagazine.com/
1969 Charger
1970 Coronet
1971 Charger R/T
1971 Road Runner
1989 VW Cabriolet
2004 SRT-4
2006 Grand Cherokee SRT8
2008 Challenger SRT8
2016 Wrangler Unlimited
2017 Ram 1500 Rebel
Offline farmertan
Re: Trailer weights
« Reply #7 on: August 18, 2009 - 11:13:24 PM »
That 4L will pull it just fine its the stopping part of the trip on the downhill side of the mountain  that could get interesting. :rofl:
Re: Trailer weights
« Reply #8 on: August 19, 2009 - 03:01:23 AM »
Where is Camjam
 he towed his chall with a Dakota , he made it out here but on the way back home it caught him off guard & the Chall ended up on it`s roof as well as the Dak, use a real truck, Camjam replaced the Dak with a Cummins
Offline 69bronzeT5
  • SRT Guru
  • Mopar or No Car
    • Forgotten Mopars
Re: Trailer weights
« Reply #9 on: August 19, 2009 - 03:32:00 PM »
Where is Camjam
The orange '71? I assume he fixed it considering I saw it last month. :dunno:
1969 Charger
1970 Coronet
1971 Charger R/T
1971 Road Runner
1989 VW Cabriolet
2004 SRT-4
2017 Ram 1500 Rebel
Re: Trailer weights
« Reply #10 on: August 19, 2009 - 03:38:37 PM »
That is correct , he fixed it immediatly
Offline 69bronzeT5
  • SRT Guru
  • Mopar or No Car
    • Forgotten Mopars
Re: Trailer weights
« Reply #11 on: August 20, 2009 - 10:12:41 PM »
How wrecked did it get?
1969 Charger
1970 Coronet
1971 Charger R/T
1971 Road Runner
1989 VW Cabriolet
2004 SRT-4
2017 Ram 1500 Rebel
