Author Topic: Restoration of an origonal owner 73 Challenger Rallye  (Read 196976 times)
Re: Restoration of an origonal owner 73 Challenger Rallye
« Reply #105 on: January 21, 2010 - 11:08:07 AM »
Not much to those vapor separators is there.  Lukily I got mine all cleaned up and the internal valve is working again.  It would still be nice to find an NOS one but I'm sure the price would be rediculous.
« Reply #106 on: May 06, 2010 - 10:13:39 AM »
Here's a few more pics...
I was curious how well the bumper fillers would fit in the new fenders/quarters so the bodyshop took some pics for me.  It looks like they fit pretty good.
« Reply #107 on: May 06, 2010 - 10:25:10 AM »
Some pics after most of the filler work was done.
...the car is not being supported by a sawhorse...at first glance it looks like it though...
« Last Edit: May 18, 2010 - 02:10:25 PM by burdar »
« Reply #108 on: May 06, 2010 - 10:42:20 AM »
The car was sprayed with polyester primer a couple days ago.  Hoping it will be painted by June 1st.
Offline dutch
« Reply #109 on: May 06, 2010 - 11:15:30 AM »
looking good  :clapping:    are you going to assemble it after paint or will the shop finish it completely?
*** Bart ***
« Reply #110 on: May 06, 2010 - 11:51:51 AM »
Once it's painted, they will apply the strobe stripes I bought from ChallengerGary and then it comes home...finally!
« Reply #111 on: May 07, 2010 - 08:26:31 AM »
  Great to see your getting SO Close.....   :woohoo:
  Have you ever determined the finish for the bumper fillers?
What color for the front & how to get the metallic look on the rear, all my attempts have had issues.
« Reply #112 on: May 07, 2010 - 08:47:31 AM »
The front fillers are natural.  I only have two options with those.  Either paint them a color that matches the natural gray or find NOS.  I think you will be able to tell they are painted so I may try to find new ones.  I havn't decided yet.
As far as the rear is concerned,  I havn't decided on that either.  There is a member on Moparts that I talked to at the Nat's last year.  He ended up doing what I suggested to him which was to spray the dark argent(Totally Auto's paint) on first and then mist the light argent onto it.  His turned out pretty good.  You won't get the same texture as factory but it is a close match in color.
I had a phone conversation with Mike from BE&A about the tail panel argent awhile ago.  He makes his own for use on the products he sells.  He has some origonal Chrysler argent samples that the factory used for quality control when some pre-painted parts came in from other suppliers.  His team spent a lot of time and money creating there own argent to match those samples.
He said he would be willing to send his painter out to shoot the tail of my car if I wanted to go that route.  The problem is that it would be a lot of money to pay his painter to drive two hours to where the car is, paint it and then drive back.
« Reply #113 on: May 11, 2010 - 08:10:32 AM »
Your PM box is full...........no  big secret so I'll post it here
Darren, I was on BRADS NOS & saw turn signal covers Part Number 3679255
http://www.bradsnosmopar.com/nos73chtusil.html
pricey as usual....so I searched the part # on a dealers web-store & got a surprise
Item Number      MSRP      Core Price      Price
3679255             $12.45    $0.00            $8.94
COVER ASSY FRT FNDR
https://www.mopar-wholesale.com/
I've got all excited before only to find out that the part is NLA or something but it would be worth checking into if your still needing these.
Good Luck
Wade
« Reply #114 on: May 11, 2010 - 09:51:36 AM »
Thanks, I'll check into those.  I'm definatly not putting the origonal ones back on the car.  They'd stick out like a soar thumb.
I'll clear out some of my PM's.  Thanks
Edit:   No longer available. :stomp:
« Last Edit: May 11, 2010 - 10:46:35 AM by burdar »
« Reply #115 on: May 11, 2010 - 03:45:37 PM »
Check around, there may be some on hand at local dealerships.. A Good dealer can search the network & locate if there are any out there.
« Reply #116 on: May 11, 2010 - 03:57:45 PM »
Tony's parts has NOS listed for $50.  I'll probably have a friend of mine do a dealer search for them first.
« Reply #117 on: May 18, 2010 - 03:32:20 PM »
Polyester primer is all sanded.  Final primer should be sprayed tomorrow night.  Planning on spraying color the 29th.
« Reply #118 on: May 19, 2010 - 09:30:19 PM »
Final primer is on.
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #119 on: May 20, 2010 - 03:25:12 AM »
That is looking good!  I can't wait to see it in color.
