OK...I guess it's time to post some more updates on the body.
When I went out to Ohio in March, I looked at a test spray of the body color. I thought the sample was too dark and also though the metalic needed to be a little heavier. The car had been repainted at least once, so holding the sample up to one of the fender louvers wasn't very helpful in determining the correct color. The shop manager said he would shoot a couple more test sprays and send them to me for final approval.
A few weeks went by and I got some samples in the mail. All three samples were very close to each other so I thought making the right choise was going to be difficult. It was then that I remembered that the origonal trunk lid for the car was still in my parents shop. The lid had been repainted in the late 70's or early 80's but the factory jack instruction decal was still in place. I also remembered seeing an inspection stamp on the underside of the lid as well. I drove over to my parents place and carefully pealed the jack instruction sticker off the trunk lid. I held all three samples up to the origonal paint and felt pretty comfortable that I made the right choise. Just to be sure...I called my best friend Paul and asked for his opinion. He came over the next day and picked the same color as I did.
The only difference in the origonal color and the color I picked, was that the metal flake was more pronounced on the lid than in the sample. I told that to the shop manager and he said that the factory didn't really care if they got full coverage on areas like that. He said the appearence of the metal flake can change depending on if the paint was just misted over the panel, or if a really good coat was layed down. He thought the heavier metal flake was just because the underside of the trunk lid didn't see full paint coverage.
With the paint color chosen, I had to decide if I wanted the underside sprayed body color or sprayed with the factory color primer with body color overspray. I know it's not correct, but I decided on having the underside sprayed body color.
So...at the end of April, the inside of the trunk, engine compartment, front wheelwell areas and underside were sprayed with JA5 dark silver metallic.
Here's the inside of the trunk.
