Author Topic: Small Block Water Pump Selection  (Read 521 times)
Offline cwestra
« on: August 19, 2009 - 07:54:42 AM »
Will I run into cooling problems if I go with a cheap water pump for my 340?  I have seen prices range from $26 to over $55.  Also, is there any advantage to a 8 blade over a 6 blade impelller?
Corey - in Northern Indiana
Re: Small Block Water Pump Selection
« Reply #1 on: August 19, 2009 - 12:43:18 PM »
8 blade will cost you 15 hp or so
Offline duodec
« Reply #2 on: August 24, 2009 - 11:37:29 PM »
If  I see a mechanical part made in China, or with a bearing that is made in China, I look elsewhere; cheap isn't worth the risk.
Offline Aracer
« Reply #3 on: August 28, 2009 - 04:59:44 PM »
 :2cents: Milodon High volume aluminum , if you have cooling problems, and their thermostat. Plus the most rows  or largest tubes to handle the extra flow. Or a smaller crank pulley to compensate for drag racing.
