Author Topic: Front ride height  (Read 903 times)
Offline 30below
Front ride height
« on: August 19, 2009 - 09:11:16 AM »
Anyone have a measurement from the bottom of the rad cradle to the ground.Just dropped the motor in and there is no fenders on the Cuda.Just need to get it approximate for now.Thanks
Re: Front ride height
« Reply #1 on: August 19, 2009 - 02:03:02 PM »
Factory ride height is measured off the lower control arm. The measurement from the to the floor to the surface of the t-bar socket should be 1.38-1.75" higher than the measurement from the floor to the lower ball joint surface (I forget which dimension it is exactly). But, if your still working on the car, adding parts and so on, this is going to continue to change. Setting the ride height should be the last thing you do before getting an alignment.
