:Hey guys! im new ! been surfing web and joined ! without a doubt this is the best forum. Heres my problems, ill just stick to the car. 1971 challanger , new 65 watt alt 2 field [says ground and field stamped in case ? ] worked out all my bugs , ie; fuses blowing, fixed meltdown in firewall junction, [2 problem term. 16, 18,] reconnected alt to batt post on starter relay, thought some idiot by passed amp because they wernt as smart as me cause im going to wire it "FACTORY" ouch ! i plead ignorance ,i didn"t know the bypass was standard practace to aleviate further problems! okey everythings great except when i turn on my turn signals or flashers altnator wire gets super hot about half way to batt terminal on relay, and # 18 gets very hot as does middle ignition red wire at connector at base of steering wheel. using # 11 gauge braded house wire [Looks ok] from alt to relay. funny thing since ive repaired and replaced a ton of splices all over, it doesnt get very hot at the starter relay term. like it used too. I actually think splices were disipating some heat as they would get hot too. Ignition switch grounding out ? any ideas what i might not be checking . allready replaced turn signal switch ,there was nothing wrong other than busted cam, so it didnt hurt to replace . okey the last clue , turn signals bleed to other side when using one or the other, and when i use flasher ,head lights pulse with flashers , pulse is not extreme, but is easily noticible thanks guys !
