Author Topic: Installing the new Goodmark Trans crossmember....  (Read 2642 times)
Offline 73Barracuda340
« on: August 20, 2009 - 10:51:00 PM »
Well 18 years after I put floor pans in my brothers 74 Cuda, it desperately needed attention in the trans crossmember area.  Passenger side was still solid but drivers side was near spinning out the torsion bar socket.
I was determined to remove the damned thing without taking out the floor pans or cutting them up to badly.  As of tonight I completed the removal (3 evenings to accomplish) of the old one.  Test fit on the new unit was very good.  A little surface rust removal on the floor pans under the crossmember, some weld thru primer, and duplicolor spray on bedliner and it will be ready to weld in.
I don't have any pics thus far, as they wife left town and took the only camera with her.  I plan to buy a new one tomorrow and snap some pics of the prep-work and installation to add to this post.
This will be the last one of these I try to remove without replacing the floor pans!!
Re: Installing the new Goodmark Trans crossmember....
« Reply #1 on: August 21, 2009 - 10:32:57 PM »
Here are some shots after removing the old crossmember.  I will replace the section of inside rocker panel behind the crossmember where the spot welds pulled out.
« Reply #2 on: August 23, 2009 - 02:20:59 AM »
Initial fitting of the replacement part.
« Reply #3 on: August 23, 2009 - 02:23:06 AM »
Holes in the floor pans for the new plug welds.
« Reply #4 on: August 23, 2009 - 02:24:45 AM »
Spot weld locations are marked so we can remove EDP finish and prime with SEM Weld-Thru primer.
« Reply #5 on: August 23, 2009 - 02:26:14 AM »
Floor pan and frame rail tabs are primed with SEM Weld-Thru primer as well.
Offline ksierens
    • 70 Challenger Resurrection
« Reply #6 on: August 23, 2009 - 10:19:37 AM »
Looks like you are doing a great job!
Kurt - SE Michigan
Offline E-Body Products
  • E-Body Products
    • E-BODY PRODUCTS
« Reply #7 on: August 23, 2009 - 09:45:02 PM »
Good job...  Lots of work, but well worth it in the end.
If anyone needs one of these, I have them on my sight.
Keep up the good work.
Daniel
www.ebodyproducts.com
dj1965@ebodyproducts.com
« Reply #8 on: August 25, 2009 - 09:37:21 PM »
The crossmember is in.  Just have to 4 more plug welds to do topside at the inner rocker and the inside-most tab on the crossmember.  I need to peel the floor pan back some more to facilitate smacking the tab against the rocker to weld it up.
Offline 426HEMI
« Reply #9 on: August 25, 2009 - 09:58:33 PM »
It is looking really good   :2thumbs:
1970 M46 Barracuda
1998 Dodge Darango
Gordon
« Reply #10 on: August 26, 2009 - 10:21:40 PM »
Daniel
Daniel....do you have the left side e-bod frame rail assembly for a 74 Cuda in stock?  If so, how much shipped to 45326 Fletcher, Ohio?
Last night I replaced a small section of rust in the right side frame rail at the shock tower, and tonight I played "Chase the Rust" on the left side frame rail.  After diving into the left side rail, I recommended that my brother purchase a left side repro frame rail.
  • E-Body Products
    • E-BODY PRODUCTS
« Reply #11 on: August 26, 2009 - 11:17:33 PM »
This is PN: 391-1570-L from AMD, but it is temporarily out of stock.  I have a 15% off promotional offer through 9/15/09 on all AMD products (Applies to AMD's list price).  This promotional code offer is EBP91509.
This does not apply to the already reduced prices on the E-Body Products website.  Also, this does not apply to any of the already reduced Sherman products offered on E-Body Products website.
I will check on availability from AMD on Thursday for you.  This piece also includes the shock tower, which is really nice.  I assume it will have to be truck freight, but I will check on that as well.
Thanks,
Daniel
« Reply #12 on: August 28, 2009 - 04:45:28 PM »
I just talked to AMD today, and they say that the complete front rails are in prototype, and should be ready for sale in 60 to 90 days depending on how fitment tests go.
  • E-Body Products
    • E-BODY PRODUCTS
« Reply #13 on: August 28, 2009 - 04:51:54 PM »
If you can wait that long, I will still let you have the promotional offer of 15% off when they are in stock at AMD.
Just let me know.
Daniel
