I am putting together a '72 Challenger for a friend. I took a look at the door window felts tonight. I am very confused!
He gave me the new window felts and I am assuming they are the correct ones. There are two with holes in them and two with clips on the backs.
I believe the two with holes in them are the outer ones and they get riveted to the door? Do these require you to drill the holes in the door to mount them? The holes from the original ones do not match up to the holes in the felts. How do you know where to place them on the door? The original one is still on the passenger door and I can see that it does not go to the edges of the door.
That would mean the other ones are for the door panels right? They do not look like they would fit the door panels.
Is there anything wierd like this for the small rear windows? Is there a trick to putting them on too?
Thanks for any help you could give me!
Jeff
