Author Topic: 72 Challenger Window Felts....HELP!!!!  (Read 2517 times)
Offline jmartin99
« on: August 21, 2009 - 09:53:37 PM »
I am putting together a '72 Challenger for a friend.  I took a look at the door window felts tonight.  I am very confused!  :banghead:  He gave me the new window felts and I am assuming they are the correct ones.  There are two with holes in them and two with clips on the backs.
I believe the two with holes in them are the outer ones and they get riveted to the door?  Do these require you to drill the holes in the door to mount them?  The holes from the original ones do not match up to the holes in the felts.  How do you know where to place them on the door?  The original one is still on the passenger door and I can see that it does not go to the edges of the door.  :clueless:
That would mean the other ones are for the door panels right?  They do not look like they would fit the door panels.   :dunno:
Is there anything wierd like this for the small rear windows?  Is there a trick to putting them on too?
Thanks for any help you could give me!
Jeff  :ylsuper:
Offline 422STROKER
  • Member Since 6/3/06
Re: 72 Challenger Window Felts....HELP!!!!
« Reply #1 on: August 21, 2009 - 11:18:02 PM »
When I did mine they were pretty self explanatory, do you have pics of your parts?
Mine screwed on to the doors, holes lined up pretty good.
Tom :2thumbs:
Tom
Offline Matt
  • 340 now a 416 stroker
  • 340 stroker 4spd "ya baby"
    • Car store automotive
« Reply #2 on: August 22, 2009 - 12:03:02 AM »
I actually just put new ones on mine today....the correct ones for my  70 are clip ones but my drivers door had screw holes(must have replaced the door at on time)so I got screw ones cause I thought they were all scre on   so I had to alter the ones I got  they were screw ones(because for the other three I needed clip ones)   ...went on pretty good on the outside up against they glass but the inside ones are a bit of a pain ..the ones that go on you moulded door panel.... :bananasmi....Matt... :canada:
Offline UKcuda
  • Tell them I'm on my way
« Reply #3 on: August 22, 2009 - 05:15:40 PM »
Not sure on Challengers but on 'cudas they don't go all the way back to the back of the door, there is a gap where the rear quarter window ovelaps, so if they seem short line them up starting at the front.
'72 'cuda
wagesofsin
« Reply #4 on: August 22, 2009 - 08:24:48 PM »
door outers have the holes , i riveted mine on.
inners on the doors go on the panels, i started at one end end slipped em on, not slid them on from end to end, know what i mean?. just roll em over the panel edge and push down.
rear outers clip on, and the inners are on the panel just like the doors.
if youd like, i can take some pics in the a.m. tomorrow. its easier than it looks.
 :2thumbs:
Offline jmartin99
« Reply #5 on: August 22, 2009 - 10:12:43 PM »
Here are close up pics of the two types I have, the top of the felts (Chrome) is pointing down in this pic...
Here is a full length pic... the one with the clips ( on the bottom in this pic)  is a couple inches longer than the one with the holes.
Wagesofsin,  Pics would be great!  Did you drill thru the holes in the felt to rivet it on with the holes that did not match up?  Most of mine do not line up!  Thanks!
Jeff
wagesofsin
« Reply #6 on: August 23, 2009 - 07:55:58 AM »
if the holes dont line up, switch sides. mine lined up fine.
ill get you some pics soon. were just getting rolling here... :sleeping:
wagesofsin
« Reply #7 on: August 23, 2009 - 08:54:16 AM »
Offline jmartin99
« Reply #8 on: August 23, 2009 - 10:30:53 AM »
Is it possible that I have felts for a '70 and the clip on one is for the outside and the rivet on one is for the door panel?   :banghead:  It looks to me in the pics above the longer one is for the door.
Thanks!
This site is awesome!
Jeff
wagesofsin
« Reply #9 on: August 23, 2009 - 06:02:57 PM »
no, your ok, the clips do go in the door, when i got my new ones they didnt have any clips.
so i riveted em on.
as for the panel felts, you should definately see a "c" type channel where they will go over the front and rear panels.
any more q's p.m. me your number, maybe i can walk you through it over the phone.
 :2thumbs:
« Reply #10 on: August 24, 2009 - 01:20:48 AM »
Thanks!
Jeff
Yes , the 70s only had the clips on the outside into the door & they make the new inners to rivit on
Offline jmartin99
« Reply #11 on: September 09, 2009 - 09:16:44 PM »
Where is the best place to get new window felts? :dunno:
Thanks!
Jeff  :cheers:
wagesofsin
« Reply #12 on: September 09, 2009 - 10:12:23 PM »
check out our site sponsors, thats where i got mine.
 :2thumbs:
