Ok guys can you help me out with a list of different grits of sandpaper that i will need for filler, priming, base and clear work. I want to buy all i need at once (probably through a wholesale outfit like eastwood) so that i am not running to the store every saturday looking for a differnt grit.
Also wondering if a set of the durablock hand sanding tools will do the trick or should i be looking at something else.
I will probably be doing most of my work by hand, so to keep me from screwing up to badly( might be the only exercise i get).
Did a little research here, and it seems that the Rage Extreme is very popular for body filler. Any last comments on filler would be appreciated also.
