Anyone converted there clock over to quartz movement?
Author Topic: Anyone converted there clock over to quartz movement?  (Read 1276 times)
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« on: August 23, 2009 - 05:43:32 PM »
Does the second hand tick each second or is it smooth like the old clocks?
Thanks
Go Fast & Have Fun...
Offline 73Chally
Re: Anyone converted there clock over to quartz movement?
« Reply #1 on: August 23, 2009 - 09:46:01 PM »
I believe it ticks.  That's the only way you can tell the difference.  Just like a Rolex and a Bolex.
« Reply #2 on: August 24, 2009 - 01:18:55 AM »
it is definatly different from the original
, I thought the new ones were smooth movemnet & the original jumped
Offline ashley_j
« Reply #3 on: August 24, 2009 - 03:43:59 AM »
Mine was redone with my rallye cluster and it seems to run and keep time great.  :bigsmile:
Jeff
 :wavingflag:
2009 Dodge Charger 3.5 (Son's Ride)
2008 PT Cruiser Turbo (Mom's Hotrod)
2006 Grand Caravan SXT (you'd be surprised)
1973 Dodge Challenger (383ci w/425HP)
NEVER FORGET!!!!!!!!!!!!
Offline 73Chally
« Reply #4 on: August 24, 2009 - 08:07:09 AM »
Actually I think you are correct.  I know it is one or the other, and that they are different.  I'm out of town so I can't verify it, but the new quartz does keep excellent time, and draws very little voltage.
    • THE DODGE BOYS
« Reply #5 on: August 24, 2009 - 07:50:49 PM »
My cluster was rebuilt 4 months back and I just put it in and I thought it should go tick tick tick and it just runs smoth sorta it will stop every 30 min or so then I have to tap it to get it to restart.  :banghead:
Offline 73EStroker
« Reply #6 on: August 25, 2009 - 02:18:55 PM »
I got mine from RTE. Electronic and the second hand sweeps continuously (IE no tick tick). Keeps perfect time over weeks down to the minute.
Barry (Salmon Arm)
Offline ashley_j
« Reply #7 on: August 25, 2009 - 04:19:17 PM »
To add... mine doesn't tick either. Just runs smooth as silk. My was done by AutoInstruments in VA.  :2cents:
Jeff
 :wavingflag:
« Reply #8 on: August 25, 2009 - 04:57:32 PM »
Mine is quartz and runs smooth. It keeps perfect time too.
To be honest, I haven't seen the kind that ticks, so to speak. I think all the original clocks have probably gone to heaven as the reason. I always look at car shows, and 90% or better have dead clocks.
Offline swede-cuda
« Reply #9 on: August 25, 2009 - 05:15:38 PM »
 :wave:hej guys.my original clock ticks and tacks,i can hear it.ive been tapping on it every time ive driven the 70, and now its been ticking and tacking for 4 days in a row.how about that.peaceout :poopoke:
Offline dutch
« Reply #10 on: August 25, 2009 - 05:22:17 PM »
welcome swede-cuda   :wave:
can`t just tick-tack in here....   :biggrin:
 :useless: :useless: :useless: :useless:
*** Bart ***
Offline Blue Meanie
« Reply #11 on: August 26, 2009 - 12:08:17 PM »
I've never seen one of these dash clocks from the back side, but mechanical clocks need maintenance.  course mechanisms like a large clock should be cleaned and lubricated at least every five years or so.  A fine mechanism like a watch should be done every two years or less (like your anti-freeze).  The oils dry up and everything just grinds to a halt.  I doubt if there are many if any jewels in the movement. And metal bearings don't last for bupkis.  Like so often, the machine is blamed when in fact it is the owners poor maintenance at fault. :naughty:
« Reply #12 on: August 26, 2009 - 05:45:45 PM »
I understand what you are saying, but I don't think doing maintenance was a priority back then.   :grinno: Check out this picture. The clock is on the far left. The back side is totally sealed. To really get at the guts, you need to pull off the hands and take out the rivets on the front to open it up. I have never tried because that seems like a PITA, so I sent mine out for the quartz conversion. Maybe others who have done it themselves will say it wasn't such an ordeal.    :dunno:
Offline miketyler
    • www.miketyler.net
« Reply #13 on: August 26, 2009 - 06:04:26 PM »
I did mine myself. It wasnt too bad. It re-uses some pats from the original movement. It even came with a VHS video tape showing you how to do the swap. Not a bad deal for $50
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
    • THE DODGE BOYS
« Reply #14 on: August 26, 2009 - 07:05:57 PM »
Miketyler
Is your second hand smoth or tick tick tick...
