Author Topic: Help with assembling steering column coupler  (Read 896 times)
« on: August 23, 2009 - 10:51:50 PM »
I remember when I took it apart but now I forget! The dimple on the steering shaft orientates how when you are assembling the coupler kit? It relates to the splines somehow?
« Last Edit: August 24, 2009 - 08:07:15 AM by brads70 »
Re: Help with assembling steering column coupler
« Reply #1 on: August 24, 2009 - 01:12:42 AM »
there is a small hole drilled into the steering shaft , it is on the same side as the dimple in the coupler & the master spline
« Reply #2 on: August 24, 2009 - 08:15:51 AM »
Neil, The small hole your talking about. Is this the one on the coupler with the small pin? If so ,then does this pin lines up on the same side as the dimple on the steering shaft?
Thanks Brad
« Reply #3 on: August 24, 2009 - 10:38:59 AM »
not sure , the 2 marks you are using are different than the ones I was using last week when I did it
Alaskan_TA
« Reply #4 on: August 24, 2009 - 04:34:18 PM »
Go here;
http://www.hamtramck-historical.com/1969-Dodge-TSB-Index.shtml
Drop down to Chapter 19 & read TSB No. D69-19-4. It is 8 pages & includes illustrations.
« Reply #5 on: September 08, 2009 - 07:42:11 PM »
Go here;
Thanks (again!) Barry! :working:
