I have a 1973 Cuda 340 727 trans. with TF2 kit.
The problem I am having has to do with 1-2 shift point on WOT. I hit 6500 rpm before it shifts to 2nd. Normal driving is perfect. I have adjusted the throttle kickdown linkage for 1-2 at 10mph and 2-3 at about 25mph. The bands are adjusted correctly, fluid level proper, I did everything the kit instructions required. Is it possible the throttle pressure valve in the valve body could cause this? I know when I was doing the kit the retainer on the TP valve was set 6 turns in but transgo wants the retainer flush all the way out. I am just trying to figure this out and could use some help, thanks in advance!
