Author Topic: 318 engine mount questions  (Read 644 times)
Offline Beck
    • BECK KUSTOMS
« on: August 24, 2009 - 05:18:16 PM »
hey guys,
i need new engine mounts for my 73 cuda.
it has a 318, but the k member has the skid plate welded on so i guess it's from a 440+6 car...
does this affect the mounts i need? anyone got part numbers or good place to pick up some mounts?
pictures would be good also.
cheers,
aaron
Re: 318 engine mount questions
« Reply #1 on: August 25, 2009 - 11:52:03 AM »
18 will bolt to the V8 K frame wiith no issues , contact Schumakers for mounts , www.engines-swaps.com
Offline Aracer
« Reply #2 on: August 30, 2009 - 12:25:48 AM »
     Are the mounts flat or round with a bolt through, if they are round then you can use the Poly Prothane or Energy S. Flat then you use stock with a restraint or the expensive Smuckers type.
« Reply #3 on: August 30, 2009 - 01:09:48 AM »
I might be wrong but I don`t recall seeing a spool type mount with a skid plate  :clueless:
