Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
Lower Steering Column Bearing
« previous
next »
Print
Pages: [
1
Author
Topic: Lower Steering Column Bearing (Read 964 times)
Harts56
Jr. Member
on:
August 26, 2009 - 12:07:06 AM »
I have a 70 Challenger. The other day I noticed the steering column where it enters the engine compartment looked odd. The column in not centered, in fact it is angled! Some older posts on the site state that there is no lower bearing from the factory, just a collar to stop metal on metal I guess.
I will try to post a picture. Just want to make sure this a "normal" and that I shouldn't get all excited.
Thanks in advance!
Logged
ashley_j
Jr. Member
Re: Lower Steering Column Bearing
Reply #1 on:
August 26, 2009 - 01:07:17 AM »
I have some pics from my '73 but I am not sure exactly what I am looking at. Look at the pics and see if they help. The second pic you can see the lower shaft and the white/yellow plastic clip that holds the dust ring (rubber/foam?) that centers the shaft in the column tube. Hope it helps.
Jeff
Logged
2009 Dodge Charger 3.5 (Son's Ride)
2008 PT Cruiser Turbo (Mom's Hotrod)
2006 Grand Caravan SXT (you'd be surprised)
1973 Dodge Challenger (383ci w/425HP)
NEVER FORGET!!!!!!!!!!!!
Chryco Psycho
Administrator
C-C.com Guru
Reply #2 on:
August 26, 2009 - 03:38:56 AM »
the plate on the firewall has oversized holes to allow the column to be moved to center the shaft up , loosen the 3 bolts on the floor plate & move the column until it is centered better & retighten the bolts
Logged
Harts56
Jr. Member
Reply #3 on:
August 26, 2009 - 10:01:03 PM »
Thanks! I'll try to center it so that it does not rub. The white plastic piece is just to keet road dirt out? Do you know where I can find one?
Thanks again!
Logged
ashley_j
Jr. Member
Reply #4 on:
August 27, 2009 - 12:04:53 AM »
I replaced mine thru Year One. I could not find the page but I have seen them on
as well. Some sell as a kit and I have seen one kit that could be mounted w/o disassembly. The one I found under general search I listed below.
http://cgi.ebay.com/ebaymotors/71-74-Cuda-E-Body-71-73-B-Body-Steering-Column-Seal_W0QQcmdZViewItemQQ_trksidZp3286Q2em20Q2el1116QQhashZitem5188ef6b46QQitemZ350189742918QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Jeff
Logged
Harts56
Jr. Member
Reply #5 on:
August 27, 2009 - 11:26:34 AM »
Found it! Thanks
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
