News:
I wonder if these "Mopar Performance" shocks are really better performing shocks or just longer than usual standard shocks? "Special drag racing applications" could mean they have poor street manners.....
Summit shows some "dragracing" shocks, but they have a warning that "90/10 valved shocks should never be used on a street driven vehicle". The Mopar shocks there dont have that warning, but they DO say 'for drag racing only"......
I would think the truck shock is valved more for street, but it would also be valved for a TRUCK versus the lighter car.....?
Rears mounted the same... re-read the post re-shock specks... see/ Lower Mount :Loop Type 11/16" x 1 9/16" & Upper Mount : Stem 3/8" x 24 listed under both shocks.
Fronts I found the lengths to be the issue, Dodge truck is actually too short. Shock - NAPA Response - FrontProduct Line: NAPA ResponseHere's the specs I used to zero in on the make/model to fit, notice that everything looks good except the lower mount...that's what I had to modify (read grind down the inner metal sleeve the bolt goes through)I've got heavier than stock torsion bars, .96, & will keep the front end lower than stock so extended length was not as big an issue as compressed length. When I compared them side by side with the old monroes that were on my car there was virtually no difference other than the cover over the rod.
