Author Topic: tail panel letters  (Read 793 times)
Offline WVUFELLA
  • (OO/---------\OO) closest i could for a 72
tail panel letters
« on: August 26, 2009 - 10:53:32 AM »
whats hold the letters on the tail panel of a 72 ? the body man put plastic sleeves on but they are cracking and breakin off letting the letters fall out.  A letter basically fell out the other day when i was washing the car..... does anyone use those self starting speed nuts like the ones that hold the metal trim piece on the door panel????
Re: tail panel letters
« Reply #1 on: August 26, 2009 - 11:02:02 AM »
THey use a nut like this.
http://rtspecialties.net/proddetail.asp?prod=1003400
I just did a search for "emblem nut" so I'd make sure that is the correct one for the application before ordering.
« Reply #2 on: August 26, 2009 - 11:48:09 AM »
My '73 had the plastic push in retainers that were pink.. I've been eying some at the hardware store but I think their too small... I've been meaning to try some barrel nuts like holds the hood callouts on. Will report back in a day or two.
« Reply #3 on: August 26, 2009 - 12:05:21 PM »
What about the hood letters?  Did they use the nuts I posted?
Here are some pink clips.  Is that was you are talking about?  I really don't remember those at all.
http://rtspecialties.net/proddetail.asp?prod=6002852S
« Last Edit: August 26, 2009 - 12:12:54 PM by burdar »
Offline WVUFELLA
« Reply #4 on: August 26, 2009 - 01:03:07 PM »
those pink clip is what the body man put on it about 4 months ago and now they are all cracked and busted looking and te letters are loose i think i will try my luck with somethin that screws on to the post that way it cant jus pull out and fall off going down the road thanks!!
« Reply #5 on: August 26, 2009 - 02:50:38 PM »
Yes that the nut for the hood.
