I have an opinion , contact McLeod , I would use a B&B / Long style clutch , only McLeod makes them
I have ad problems with the MP clutches in the past , you will need to re-install the overcenter spring
McLEod has different weigth clutch pressures to hold the power you are making without excessive pedal pressure
