Author Topic: Power Brake Booster Piston Lubricant?  (Read 961 times)
Offline cwestra
« on: August 26, 2009 - 04:37:32 PM »
Attached is the piston assembly from the rear of my booster.  When I reinstall this should I lubricate it with anything?  Also, the diaphragm boot area where the 2 halves of the housing join together were fairly rusty.  In order to achieve a good seal can I use a permatex sealer or something else?  Or will I be fine without anything?
« Last Edit: August 26, 2009 - 04:43:43 PM by cwestra »
Corey - in Northern Indiana
