Author Topic: Manual squirters  (Read 1413 times)
Offline Purple73Cuda
Manual squirters
« on: August 28, 2009 - 12:38:10 PM »
My 'Cuda has a manual w/s squirter setup. The wiper switch pushes in like on a electric w/s squirter setup. Is that correct for a manual squirter car? Or did someone put a manual sertup in for some reason?
I don't have a fender tag or b/c sheet.
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
Re: Manual squirters
« Reply #1 on: August 28, 2009 - 05:19:51 PM »
The non manual switch does not push in
Cant kill the mean and ugly. Only the good die young...I plan to be here a while!!
« Reply #2 on: August 28, 2009 - 06:25:26 PM »
I would guess it would be pretty easy to convert to electric squirters if the washer switch works. Has anyone done this? Anyone have any tips?
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
« Reply #3 on: August 28, 2009 - 08:30:56 PM »
there should be 2 brown wires in the harness that will connect to the wiper switch to send power out to the pump , 1 wire is power in the other is power out to the pump , the in wire may connect internally in the switch , all you need is a tank with a pump or an inline pump , connect the brown wire & ground & the squirters should work
« Reply #4 on: August 28, 2009 - 08:31:46 PM »
 This actually wrong , the manual switch will not push in , the power switch pushes in
Offline 422STROKER
  • Member Since 6/3/06
« Reply #5 on: August 28, 2009 - 08:33:19 PM »
Someone must have converted to a 3 spd/var wiper.  2 speed motors didn't get the wash option.
Tom
Tom
« Reply #6 on: August 31, 2009 - 07:09:23 AM »
Tom
Tom,
I think you might be right. I took a look at the switch on Sunday. It is a 3 speed switch which does push in to activate the squirters. I will have to get a wash bottle and pump and convert to electric washers.
Were the standard wipers two speed in '73? Were all 2 speeds have manual squirters?
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
Offline 422STROKER
« Reply #7 on: September 09, 2009 - 05:52:37 PM »
If it's a 3 speed switch then you have the motor to match?
I did a little research when fixing mine with the 2 spd stuff and couldn't find a 2 spd with wash option for the e-body.
The wiring should be there either way, it is a brown wire on my 72 should be similar in other years.
Tom
Tom
« Reply #8 on: September 10, 2009 - 08:14:17 AM »
I have the 2 speed wiper motor. (I am assuming a 3 speed in an ebody is similarly shaped to a B body 3 speed).
What I think happened is someone changed the whole dash board at one time. The reason I say this is, after having the 'Cuda on the lift I see no evidence of the floors being touched or a 4 speed hump being installed. My car is a 4 speed but has no reverse light indicator on the dash. The wiper switch is a 3 speed switch. The car has a manual bottle and the foot pump mounted to the floor. Although the rubber hose is missing the special grommet is in the firewall.
I am missing the fender tag so all of my above statements impossible to confirm.
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
Offline 422STROKER
« Reply #9 on: September 10, 2009 - 09:07:31 PM »
Do your wipers currently work?  The 2spd wiper sticks straight out and the 3 spd lays down.  I don't think the 3spd switch will work properly with the 2 spd motor.
Tom
Tom
« Reply #10 on: September 11, 2009 - 07:09:24 AM »
Tom
Tom,
Yes my wipers work. The wiper motor sticks straight out.
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
Offline 422STROKER
« Reply #11 on: September 11, 2009 - 07:34:46 PM »
Nice, if you get a chance to snap a pic of the switch on the backside that would be great, I'd like to see how they got the 3spd switch to work with the 2 spd motor.
Tom :2thumbs:
Tom
