Author Topic: Road Lamp bolt question  (Read 650 times)
Offline 67vertman
  • Member since 9-23-2005
« on: August 28, 2009 - 10:17:11 PM »
What size bolts hold on the Road Lamp brakets?
Do you need longer chrome bummper bolts?
any pictures would also help.
I picked up a pair of brakets and lamps on ebay but they did not have the bolts.
Thanks.
Re: Road Lamp bolt question
« Reply #1 on: August 28, 2009 - 10:36:43 PM »
The one existing bumper bolt should long enough (stock) then the other part of the bracket is a standard thread 3/8ths bolt nut and washer that goes through the bumper bracket hole
Offline 67vertman
« Reply #2 on: August 28, 2009 - 11:07:27 PM »
Thanks Alan.  You are always first to respond.  :2thumbs:
I found a picture of the bolts but I couldn't tell the size.
Thanks to you I have all that parts I need to put them on.   :jumping:
P.S.  Where does the relay mount under the dash?  I see it has a bracket so it must mount to soemthing.  :clueless:
