Author Topic: Rear disc brake question  (Read 524 times)
Offline Hopalong
  • HEAD OFF! Apply directly to the neck line!
« on: August 29, 2009 - 12:01:46 PM »
Has any one used a disc brake set up without changing to the "green" bearings?  I see that pretty much all the kits offered "require" the use of the green bearings.  How much does the axle actually move and would it really be a problem with the factory style bearings?
{oo/===\oo}
Re: Rear disc brake question
« Reply #1 on: August 29, 2009 - 12:31:51 PM »
I think the SSBC kit works with the normal brgs
Offline shawge
  • Zoiks!!
« Reply #2 on: August 29, 2009 - 12:42:05 PM »
Give Cass at www.doctordiff.com a call/email.  He's got a setup that uses 2006 Mustang calipers that work w/o going to the green bearings.  He's got excellent customer support.
- Jerry
