Author Topic: Oil Pump Question (Small Block)  (Read 697 times)
Offline cwestra
« on: August 29, 2009 - 06:05:09 PM »
When installing the oil pump in my 340 I noticed a gap between the main cap and pump interface.  It appears to be bottoming out at the drive post area.  Is this right?  Are there gaskets that go here?  I didn't recall having any when I removed it?
Corey - in Northern Indiana
Offline 426HEMI
Re: Oil Pump Question (Small Block)
« Reply #1 on: August 29, 2009 - 06:38:42 PM »
Yes there is a gasket that goes there.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline cwestra
« Reply #2 on: August 29, 2009 - 07:36:43 PM »
Thanks, found it.  Who would have guessed it was in the box (lol).  Still looks too thin to make up the gap difference though.  Is is supposed to be like that?
Offline 72cudamaan
« Reply #3 on: August 29, 2009 - 07:54:35 PM »
Yep, needs the gasket, and no ther should be no gap ( big pressure leak).
If I cant fix it, it's broke
Andy  (phukker whither)
Offline cwestra
« Reply #4 on: August 29, 2009 - 07:57:19 PM »
Taking a closer look at it, it appears that the new pump drive bushing installed my my machine shop is preventing the pump from seating.  It looks like the bushing is extending down a little too far.  Has anyone seen this before?
Offline 72cudamaan
« Reply #5 on: August 29, 2009 - 10:03:56 PM »
Are you sure that a tap or 2 with a mallet wont seat that pump.  Looks like a tight fit.
Offline moper
« Reply #6 on: August 29, 2009 - 11:47:15 PM »
The pump should never be hit. You want to make sure the gasket surface is flush with the main cap. If there is a minor amount of machined area visible on the drive section I wouldnt worry. So long as the gasket surface comes together right. It isnt a pres fit there. Just a passage the oil pump passes thru.
Offline dodge freak 2
« Reply #7 on: August 30, 2009 - 01:33:57 AM »
Instead of striking the pump body--which might be fine to do--I would bolt the pump on without the gasket to see if you can easily get rid of that space. The brushing might easily move up a bit then with the gasket install there be aslight space in between the pump shaft and the brushing.
If it does not move easily you could break the pump and or main cap..I say no more than 15 lbs of torque I would push on the bolts. I would then take the block back to the shop.
Offline 72cudamaan
« Reply #8 on: August 30, 2009 - 09:17:27 PM »
Oh moper, notice I didn't say hit the pump. I said Tap WITH A MALLET. Obviously hitting it with a hammer could crack the ear. :screwy:
Offline cwestra
« Reply #9 on: August 30, 2009 - 10:01:57 PM »
Drawing it down with the bolts does appear to close the gap up uniformly across the surface (w/o gasket).  I used my old pump just in case.  When I remove the pump the gap comes back so the interference area is flexing elastically, not plastically.  Hopefully this wont be an issue.  I am confident I'll have a good seal between the pump and main cap.  Thanks for all the help.
Offline moper
« Reply #10 on: September 01, 2009 - 12:04:09 PM »
It's only cast iron. Dropping it on concrete can be enough to render it inoperable. This does not require force of any kind (including pulling the pump down with the bolts) if everything is kosher. You set it in the hole for the drive and lower it onto the main cap where with no effort but your hand it should sit flat. Then start the bolts by hand. Things like dampners, piston/rod assemblies, setting thrust bearings... They all will take more... persuasion.  Not installing the oil pump.
