Author Topic: Test voltage regulator  (Read 906 times)
Offline the_engineers
« on: August 30, 2009 - 02:39:56 PM »
Is there a way to test a voltage regulator to see if it's bad?  I know they're relatively cheap, but the process always seems to be to swap them or test around them.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Alaskan_TA
Re: Test voltage regulator
« Reply #1 on: August 30, 2009 - 03:31:51 PM »
Yes, but you will have to pirate a bad one to make one of these. I made this over 20 years ago, so it needs a rebuild.
To make one, solder a wire to the back of the pin shown. Rivet a plastic shield to protect it some.
To use it, plug the regulator harness into it & attach the aligator clip to a good ground.
I only used this in situations where the car would not start. If this allowed the car to start I would replace the regulator. If there was no change I would look elsewhere.
Leaving it on could fry other components, so use with caution.  :2cents:
Alaskan_TA
« Reply #2 on: August 30, 2009 - 03:37:44 PM »
Offline ShelbyDogg
« Reply #3 on: September 05, 2009 - 10:33:47 AM »
Whoa Barry,
That grounds an alternator field terminal and will put your system at full charge. It could melt your battery. You could use it for a minute to test that your alternator is working, but you could do the same thing by grounding the correct field terminal at the alternator.
The only real test I use is swapping it with spares and a volt meter on the battery. I didn't read the links Barry posted yet though.
