My new Mallory 110 fuel pump is acting up and I figure I might as well install a fuel bypass to take some of the pressure off it, though Chryco you think it shouldnt be needed, but...I have the return line still mostly in place from just behind the right front wheel, back to the connection behind the rear wheel, where it has been capped off. I have several questions.
First, can anyone tell what type regulator this is, and more importantly, does it look ok to add a return line to it? assuming that is what the rear nipple is for. Also, how do I adjust the pressure with the top valve? Do I need to install a downflow pressure gauge, back off the nut, and tune it in, and tighten the nut again? Any more specific directions or advice?
Also, rather than reroute the return line to the sender on the left side of the car, can I just return the fuel back through the existing connection in the picture? Will that find its way back into the tank safely and efficiently? I think I read somewhere in here that some do it that way?
Thanks.
