Author Topic: linkage adjustment??????  (Read 5087 times)
Offline WVUFELLA
  • (OO/---------\OO) closest i could for a 72
Re: linkage adjustment??????
« Reply #15 on: September 12, 2009 - 09:34:43 AM »
sweet that is what i am lookin for .... just got the car where i can drive dont want o drop 800 or 900 in another tranny thanks guys
Offline ShelbyDogg
« Reply #16 on: September 12, 2009 - 10:25:44 AM »
When you're finished getting this to shift right, Make sure that you check that your throttle doesn't stick at wide open throttle. That's the linkage that does it. Just open it all the way with your hand and see that it returns.
Offline WVUFELLA
« Reply #17 on: September 15, 2009 - 08:37:06 PM »
ok guys i put the bolt and nut thru the rod with the slot in it... and it now shifts 1-2-3 like it is supposed to to.....however when you romp it it doesnt kick down.. do i need jus to keep tweaking it one way or the other... or do i have bigger problems??
Offline tactransman
« Reply #18 on: September 15, 2009 - 08:39:57 PM »
Keep sliding it up till you get passing gear. You will probably find out that when you get where you need it,it is going to keep your throttle blades from going wide open. Let me know if it does.
Terry-tactransman
Union, Mo.
Offline WVUFELLA
« Reply #19 on: September 15, 2009 - 09:00:39 PM »
how would the linkage prevent the throttle plates from opening up all the way .. I thought once it shifted 1-2-3 then the kcikdown would work correctly?? obviously i am wrong can you explain???
Offline tactransman
« Reply #20 on: September 15, 2009 - 09:51:10 PM »
You can have the ratio's wrong between the lever on the carb and the lever on the transmission. If the lever ratio on the carb is too slow,then you have to increase the adjustment to make up for it. Then the lever on the transmission can be maxed out in it's swing travel and the carb is not all the way open yet. Did I explain that OK?
Terry-tactransman
Union, Mo.
Offline WVUFELLA
« Reply #21 on: September 16, 2009 - 06:52:19 AM »
ok thats makes sense.. thank you
Offline WVUFELLA
« Reply #22 on: September 21, 2009 - 01:40:38 PM »
you called it tactrans.... now it is shifting good 1-2-3 but it seems to run out of pedal which is what i think your talking about the throttle not opening all the way up ... so whats next ????
Offline tactransman
« Reply #23 on: September 21, 2009 - 02:17:22 PM »
You can take the short throttle valve lever off at the transmission,cut a section out of it and weld it back so it is shorter. That makes the ratio faster down below.
Terry-tactransman
Union, Mo.
