Author Topic: Axle Housing Seals??? (Pictures)  (Read 1413 times)
Offline Glennster
« on: August 31, 2009 - 09:26:11 PM »
 Here's a few pics of the seals that came out of the Rear Axle Housing. I would guess that these are the seals that stop the Diff Oil from making it's way to the Rear Axle Bearings.
  Where can I buy new ones?
The four Gaskets in the picture where on the end on the Axle Housing, there were two on each side, is than correct? Where can I buy them?
Last, that big piece of steel that was bolted on the Diff (on the left in the picture), what is it's purpose?
Offline Katfish
  • 70 Challenger
Re: Axle Housing Seals??? (Pictures)
« Reply #1 on: August 31, 2009 - 09:36:30 PM »
Offline Glennster
« Reply #2 on: August 31, 2009 - 10:10:37 PM »
 The local guys here don't have squat......
Offline jims challenger
  • 1970 DODGE CHALLENGER
« Reply #3 on: August 31, 2009 - 10:17:12 PM »
Dr. Diff for parts,   pinion snubber is the piece on the left
http://www.doctordiff.com/
« Last Edit: August 31, 2009 - 10:21:22 PM by jims challenger »
Life can be Challenging
« Reply #4 on: August 31, 2009 - 11:34:49 PM »
The pinion snubber restricts the axle from rotating too much on hard acceleration. It's part of the reason you don't use traction bars on chryslers.
« Reply #5 on: August 31, 2009 - 11:37:15 PM »
Try your local dealer. I just ordered axle seals from my local Dodge dealer. Said I'll have them in two days.
« Reply #6 on: September 01, 2009 - 03:31:20 AM »
Find a good parts store , CR makes the seals & Fel Pro still has the gaskets
« Reply #7 on: September 01, 2009 - 11:37:41 AM »
Dodge parts counter just called today to tell me he can't get them anymore. Said he got one notice that they were shipped, and then another to say "no longer serviced"
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #8 on: September 01, 2009 - 12:12:19 PM »
inner seals are available, as well as the foam and steel gaskets. LOOKING AT 54.00 + usps if you cant find them locally. the steel gasket should not be doubled up,
that price is for 2 inner seales,2 foam gaskets, 2 steel gaskets.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline Katfish
  • 70 Challenger
« Reply #9 on: September 01, 2009 - 09:51:07 PM »
If you don't want to wait, you can get everything locally, worst case is they take a day to get it from warehouse.
Backing plate gaskets (metal)            Felpro 55032
Backing plate gaskets (foam)             Felpro 13800
Inner Axle seals                              National 8695S
Outer Axle seals                             National 8704S
« Reply #10 on: September 01, 2009 - 10:36:50 PM »
I got them no problem from my local jobber?
« Reply #11 on: September 01, 2009 - 10:47:22 PM »
Inner axle seals and outer axle seals? I just took my axle shafts out and only found a nearly non-existent foam seal gasket, an axle housing to backing plate steel gasket and an axle shaft seal within the tube. What is the outer axle seal?
« Reply #12 on: September 01, 2009 - 11:47:18 PM »
the outer seal is installed before the brg on the axle & you have to remove/ distroy the brg to relace it , it only keeps the dirt out iof the axle brg grease so it is rarely changed out unless the brg needs to be replaced anyway
Offline shadango
« Reply #13 on: September 04, 2009 - 09:57:07 PM »
I noticed that the steels were doubled up on mine too.....  :dunno:
