Drive Shaft Color???
Author Topic: Drive Shaft Color???  (Read 2875 times)
Offline Glennster
« on: September 01, 2009 - 10:13:13 PM »
 What is the correct color for an E Body Drive Shaft?
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
Re: Drive Shaft Color???
« Reply #1 on: September 01, 2009 - 10:20:56 PM »
rust or rusty brown  :poopoke: :roflsmiley: :roflsmiley:
black is best IMHO I would never paint one silver that would be crazy  :screwy:
Glenn
Try wiping it down with Paint  thinner before you paint it. :bigsmile:
black with a Silver metallic would look nice  :ylsuper:
Go Fast & Have Fun...
« Reply #2 on: September 01, 2009 - 10:48:56 PM »
Offline 71chally416
    • The Streetwalker
« Reply #3 on: September 01, 2009 - 11:07:09 PM »
« Reply #4 on: September 01, 2009 - 11:16:32 PM »
The driveshafts were unpainted from the factory.  I know there was a good post about this on Moparts.  I'll try and find the link tomorrow.
I think guys were getting close to the correct look by painting the shaft with a chrome paint and then rubbing it down with old newspaper.
« Reply #5 on: September 01, 2009 - 11:48:39 PM »
I thought they were all FM3 Panther Pink  :smilielol:
« Reply #6 on: September 02, 2009 - 08:24:16 AM »
I sandblasted then used 180 & 240 grit in a circular pattern then smoothed with a scotch brite pad. Used wire wheels to shine up the ends & finished with satin clear..
« Last Edit: September 02, 2009 - 08:36:31 AM by Bullitt- »
« Reply #7 on: September 02, 2009 - 10:31:31 AM »
Bullitt...
The bare steel parts of yours that I've seen look really good.  There are a few problems with that though.  For those of us in the "rust belt" our parts aren't good enough to just leave bare.  My driveshaft has a good amount of pitting as does my other suspension parts.  Right now I'm working on my upper controle arms.  I'm filling in a lot of the pits and will be spraying them with a paint that looks like bare steel.
Second...I have heard(I don't have any experience with this, I'm just going by word of mouth) that clears will start to yellow over time.  Also, clears are not that good at stopping the oxidation process and the parts will start to rust underneith the clear at some point.
With that being said...I do think it looks the best to have the parts bare instead of a lookalike paint but for those who are going to drive their cars in different kinds of weather, paint probably makes a better choise.  Now I don't know what your plans are with your car but if you are going for an OE type restoration, your doing the correct thing. :2cents:
« Reply #8 on: September 02, 2009 - 11:00:25 AM »
Here is the link from Moparts.  There is a lot of good info on there.  CHeck out the pic from Dave at ECS.  If any of you havn't see the pics of his car...you need to.  His Challenger has the highest score EVER in the OE judging at the Mopar Nats.
  http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Board=A12&Number=5110985&Searchpage=1&Main=5099322&Words=driveshaft&topic=&Search=true#Post5110985
Offline Glennster
« Reply #9 on: September 03, 2009 - 07:01:55 AM »
Bullitt-
 That looks FANTASTIC!
I need new brake lines and fittings for my new rear, where did you get them?
« Reply #10 on: September 03, 2009 - 08:34:33 AM »
My brake lines are OE.... a good source is http://www.inlinetube.com/
moparniac
« Reply #11 on: September 03, 2009 - 09:03:13 AM »
Aluminum color  :bigsmile:
