Author Topic: Hemi oil pan 6 QT Question  (Read 2968 times)
Offline mickey
« on: September 02, 2009 - 10:30:10 AM »
Just purchased a 6 qt oil pan part# P5007807AB centre sump and matching 3/8 pick-up. stamped on pan # 971, it has baffles welded top of sump, did not expect for these baffles to be there. would a windage tray still be used here? what is the difference in the hemi pan 6 qt part # P4529884? any advantage over the other..thxs
Re: Hemi oil pan 6 QT Question
« Reply #1 on: September 02, 2009 - 12:23:16 PM »
the baffles & windage tray are used together , the baffles stop the oil sloshing away from the pick up tube during acceration & braking , the widage tray removes oil from the crank & keeps the windage from the crank from foaming or lifting the oil inside the pan
 Not sure on the differences between the part #s , even Mopar doesn`t seem to know as the volume of that pan changes in the different catalogs from 5-6 qts
Offline mickey
« Reply #2 on: September 02, 2009 - 08:29:25 PM »
 :2thumbs: i got a stock pan with no baffles in sump , another question had the new pan and stock pan side by side not much difference ,actually they look the same height,thought there would be a noticable difference being an extra capacity pan or is it? thxs again
« Reply #3 on: September 03, 2009 - 12:29:40 AM »
the depth is maybe 1/2" different but the sump should be longer
Offline mickey
« Reply #4 on: September 03, 2009 - 11:03:33 AM »
Thxs CP   :2thumbs:
Offline mickey
« Reply #5 on: September 10, 2009 - 11:12:18 AM »
I was looking on Mancini Racing site they advertise the same pan & part #  as a stock factory pan with baffles unlike mopar book advertise the same pan & part# but as a six qt pan , seems like a stock pan to me. Would I  be safer to order the hemi oil pan 6quart and the hemi pick-up 3/8 p4529565 match for that pan,would the hemi pick-up be the same pick-up for the 440??? and will also use a windage tray.  I will be using the 1/2 pick-up on another 440 build later. thxs
« Reply #6 on: September 11, 2009 - 03:35:57 AM »
I would by the matched set from Mancini
 the 440 were all 3/8 tube pick ups , the Hemis were all 1/2 "
 the windage tray will interchange unless you stroke the engine
Offline mickey
« Reply #7 on: September 11, 2009 - 10:37:59 AM »
Thxs again CP, Hemi pan/pick-up is on the the way... :2thumbs:
